i have a 77 evinrude 9.9 model 10755a that is leaking fuel out of the inlet connection when i prime it
-i tried replace the tank side fitting brand new still leaks from in between
-the surface between the 2 is clean
i tried to get the flathead bolt out to inspect closer but no luck, any ideas where i should turn to
