77 9.9 leaking fuel from inlet, need help
mcody613
i have a 77 evinrude 9.9 model 10755a that is leaking fuel out of the inlet connection when i prime it
-i tried replace the tank side fitting brand new still leaks from in between
-the surface between the 2 is clean
i tried to get the flathead bolt out to inspect closer but no luck, any ideas where i should turn to
Vic.S
Presumably the leakis at the connection to the motor , not the tank.
The seal is made by an O ring in the connector. It is a separately listed part ... check it is there and undamaged,
usually reckoned to be best to buy genuine OMC/BRP replacement for the connectors,
Also beware of other very similar connectors which look the same but do not fit properly( been there got the tee shirt!)
oldboat1
Your connector might be a little gummed up. Try depressing the valve slightly (artist brush handle works well), and spraying with a bit of carb cleaner. Keep it all away from your face -- fuel in the line will be under some pressure.
F_R
Honorary Supreme Mariner
Yes, you said you replaced the connector and it still leaks. Sounds like possibly you didn't replace it with the correct one?? There are others that look alike but do not fit (Yamaha for one).
oldboat1
^^That's a good point. And even if you have the right connector, it may be that the new o-ring is really tight -- possible the connector isn't "clicked" into place.
