I have a 77 6hp that I got with a boat. it looks like it was used with no gear oil and burned up the gears. I found a used set on ebay and when I got them the pinion gear was slotted for a keyed drive shaft. the problem is my shaft is splined.
does anybody know if I looked for a keyed drive shaft it the spline vs keyed is the only difference?
the drive gears do have a different pitch but they do fit in the housing fine with no clearance issue.
