77 15 Hp Evin. O.b. Water Pump/impleller Concern
MAC11
Hi,
I've got a 77 15 hp Evinrude o.b./tiller/long shaft. I replaced the water pump housing and impeller last season. Before and after the repair I noticed that water does not come out of the exit hole w/any force. I was told that Evinrude uses a VOLUME IMPELLER vs say, Merc. that uses a PRESSURE impeller. Any:cool: truth to this or do I have a water pump/impeller problem. ?
tashasdaddy
Re: 77 15 Hp Evin. O.b. Water Pump/impleller Concern
sounds like you are ok. as long as you are getting water out the relief ports. the tstat has to open to cool the motor, and then you get more water.
