76' Mercury 4.5hp flooding
JJ. in B.C.
When i prime the motor with the rubber bulb gas floods out the top of the carb assembly, with a clean plug motor will start and run good for about 5 seconds before it floods out and gas runs out the drain hole on side of motor.
Thanks for your help., JJ.
Camo Joe
Re: 76' Mercury 4.5hp flooding
The float valve inside the carb bowl is not shutting off the fuel flow as needed..........the needle and or seat is dirty, damaged, or not set correctly. A complete carb cleaning may be needed along with replacing any damaged or worn parts..................
Wingedwheel
I agree with CamoJoe. Normally thats caused by a sticky float problem.
