76 Merc 850 fuel pump rebuild?
eroth111
Hey guys, I've been having some fuel delivery problems with my motor. Im rebuilding the carbs as well as the fuel pump. I know how to do the carbs but I don't know what to do with the fuel pump, or where it even is for that matter. Whenever i pump the bulb in the fuel line, it never gets stiff and if i take the motor casing off i can see fuel squirting out this round thing on the side of the motor when I'm pumping it. Any thoughts or pictures?
Thanks
chum1
Re: 76 Merc 850 fuel pump rebuild?
probably 25-35480 oring leaking on the round fuel filter, start with that first.
eroth111
yeah i bought a fuel pump rebuild kit for it. I just didnt know how to install it, but i think i figured it out thanks to that diagram. Also im new to this, where would i find the S/N on my motor?
carholme
S/N should be on a data plate screwed to the swivel bracket. You should be able to see it from the front looking between the two transom clamps which hold the engine to the boat.
Gerry
eroth111
Ok ill see if I can find it. Thanks again
