Re: '76 Merc 1500 Tower of Power Prop Question
Rule of thumb is "about" 200 rpm per inch. I think I would start by varifying the tach and speedo.A gps is best for speed.Be sure connections are clean and tight.Note the position of the selector on the back and operate it a few times to clean the contacts.For that little boat I don't think a 21 is excessive.
Check your setup The antivent plate(just above the prop) should be visable at speed.usually ends up about an inch above the bottom,measured with a straight edge along the keel.Carefully adjust trim,does the boat respond to trimming out.
(prop away from boat)Does the boat get up on the water or does it lay down like its glued to it.Prop in excellent shape?Throttle plates opening all the way?Motor timed correctly?
As far as elevation you technically need to rejet for the elevation.leaner, smaller jets.You could instead go with a lower pitch and after you have fine tuned your setup You will know better what you need for both conditions.Ideally a rejet and prop change is best.
