76 Johnson upper drive shaft
12
The 2 pieces of the shaft spin . How are they held together?
Honorary Supreme Mariner
And what motor do we have here ?----Model # required.
12
Model # 85ETLR76G 1967 85HP johnson v4.
Unless the motor has a newer replacement lower unit the shaft is broken.-----In 76 it was assembled by installing a stainless shaft into hardened shaft bottom piece.
12
Ok thank you. Will shaft out of 1972 (same motor type ) work?
The 72 was electric shift and had a different spline at the top of the shaft.----That is a definite NO IT WILL NOT FIT.
