Coltrickle
Thread starter- Joined
- Sep 16, 2012
- 108
I bought an 84 Lowe 16' boat with a 76 Johnson 70 hp. The boat starts and runs great in a barrel and on muffs.. The spark will jump over 5/8 of an inch and it has 124 psi on two cylinders and 120 on the 3rd cylinder. When i went to the lake it starts and runs great but it does not jump out of the whole. It takes about 15-20 seconds to plane with me and my son in the boat.. Bout 350 pounds.. After plane it runs great through the rest of the throttle unless you allow the boat to settleback off plane.. Then we start the process over!! A friend suggested I check the prop. It has a 13 3/4x 19p on it. My 270 hp ski boat only has a 14.25 x 19p 4 blade and is 4 times the power.. I'm no expert but it seems a bit wierd for the power ratio.. Am I correct in my thinking or should I look elsewhere?? Thanks in advance for any advice!!
