I'm having some issues with my motor running smoothly. I put 12v to the coil because I hooked up the ignition switch wrong. I had one of the magnito leads going to a 12v terminal on the switch. After frying two coils I got that figured out and got a new coil on. Then I had the coil leads mixed up. I got that fixed and now it runs like crap. It ran fine before I messed with the ignition switch and fried the coils. I took off the flywheel to check the woodruff key and it looks good. See pictures below. I set the point gap (0.02") and put it back together and it still runs like crap. See link to youtube video. So I need your guys help on where I should look to next.
1. Does this damage on the inside of the flywheel look bad?
2. Does the damage to the magneto thingys under the flywheel look damaged?
3. Could I have fried some other part under the flywheel?
Thanks for your time.
http://www.youtube.com/watch?v=EIueA9ceNlQ
