76 johnson 200 cuts out when throttle up
sully9
hello everyone I took my boat out for the first time last weekend and when I thottle up it chokes out so I can only go about ten miles a hour and I know that motor has more to it than that. any help would be appreciated thank you!
emdsapmgr
Re: 76 johnson 200 cuts out when throttle up
That engine will seem to run fine when only running on 3 or 4 cyls. Check each plugwire to make sure you have fire on all 6. A simple cyl drop test will tell you a lot about the spark. You can pull each plug wire off a spark plug when it is running. Normally when you pull a wire of a plug, the engine rpm's will go down somewhat. Reconnect the plug and go on to the next. etc. If you pull one plug off and the rpm's don't change, that plug may not be firing. You can get the same results with an inductive timing light. If your spark check out, then start looking at the fuel system.
sully9
thanks for the reply emdsapmgr I took it to my local boat repair guy and he said one of the power packs he thinks has gone out. He was going to do some tests to make sure before ordering one but it makes since to me why it was not running so well and it was a pain in the butt to start. thanks again
emdsapmgr
Very possible. The nice thing about these early V6 engines is that they have dual packs. The can be swapped for testing purposes-very helpful in misfire diagnosis.
