When a dealer is given a lower unit that has a suspect leak, the dealer performs two tests on the lower unit, once it is drained of oil: 1. He pressurizes the lower unit. The lower must hold a certain pressure for a few hours (some leave it pressurized overnight.) 2. A vacuum test is performed on the lower unit. It must hold a vacuum for a specified time. If the lower unit fails either the vacuum or pressure test, it will need to be re-sealed. A factory seal kit is obtained and the following seals are replaced: dual prop shaft seals, Carrier oring seal, drive shaft seal, Shift shaft oring and shift shaft housing seal, Four carrier bearing bolts w/oring seals. This is the typical procedure to repair a leaky lower unit gearcase.
