76 evinrude 55hp problems
rebuildj
I have a 76 evinrude 55hp outboard 55672E I have rebuilt both carbs new gas lines from tank to the carbs plus new gas tank new water pump impeller and housing alot of tinkering trying to figure it out compression is good and spark on both cylinders but on the timing arm the set screw is all way in to keep it idling but it acts as if it's power deprived at full throttle cuts in and out every once in awhile and seems like it could just scream across the water but it don't I'm puzzled on it been trying to get it lined out for about a year now ordered new fuel pump also it'll be in tomorrow but I don't think it's my problem
mfkadz
You said it feels like it could scream across the water. How fast is it going? What's the regular speed.
I just fought an intermittent issue where the motor would want to slow and then kick back in. Or skipping at higher rpm. I have the same motor and year. Have you replaced the spark plugs? One of mine was kinda working and I could see spark. But it was loosing it's punch and then just opened up and stopped working. Fought that for a few weeks. Changes a bunch of stuff before the plugs. If you have no idea how old they are. Change them. Champion has a 2 year warranty. I will be replacing mine every other year.
Also, my timing screw is almost fully adjusted in and the timing is spot on. You should check yours to be sure though.
mike
rebuildj
Just put new plugs in end of last year and not for sure how fast it's going speed cluster don't work but when it's at full throttle you can hear it try to pick up but it won't if I'd have to say it's prolly 10-15 mph and it feels as if it should do better than that and if I screw the timing screw out it won't idle in water but will with muffs hooked to water hose but it was kind of dragging around yesterday took it to the lake and at first it would plain out then it wouldn't so reached back and pumped the bulb couple times and then it plained out and ran better going to pick up new fuel pump today
rebuildj
And how would I check timing what's the timing suppose to be at
mfkadz
SO, its starving for fuel and you can add fuel via the bulb. Then it runs ok till it starts starving again. Ya, I would think fuel pump. You can remove it and disassemble and know for sure in just a couple minutes.
mike
rebuildj
Yea that's what it seems like it's starving for fuel going to pick up the new fuel pump now but with the bulb primed I can squeeze it and on the old fuel pump it makes a pssh sound but the bulb is still primed
rebuildj
But with the old fuel pump I can pump it running full throttle but it don't open up like it should maybe pumping the bulb pushes to much fuel l and it has slow take off takes it a min to get plained out
rebuildj
So here's the update new fuel pump on runs way better finally got that extra power it was lacking top speed 30 mph think it needs some fine tuning on the carbs plains out kinda quick takes a min to get top speed kind of runs ruff when you just put it in gear saw something on here that said your suppose to put it in gear to tune the carbs right not for sure I tuned the carbs in nuteral not in gear could that be why in nuteral it idles fine and in gear it idles rough any help would be much appreciated
Bosunsmate
