bktheking
Thread starter- Joined
- Jul 29, 2008
- 5,057
The gent who owned my 15 complained of a fouled bottom plug. When I got the motor home I checked compression, 95 top and bottom. The motor starter first pull. When I took it apart for paint I noticed that the bottom crank seal had let go, the spring had folded. So I put in a new seal and put it back together. I ran it today in the barrel and it had no power in gear, I pulled the top wire and it died yet I have great spark, points clean, plugs new, coils new, wires new even tried a different condensor. I pulled the plug after running it and tapped it on the 2x4 I was using on the test barrel, water. I pulled the head, bottom cylinder is crystal clean, much like the plug- an indicator of water. Check the head and block, no crack no nothing. Now I noticed when I spun the crank, a sucking sound with accompanying gas occured top cylinder, bottom had brown liquid laying in the bottom which I am assuming is watered down gas/oil mix but no sound on the bottom cylinder. Is the cylinder washed down? Why no sound like the top cylinder? I'm going to try the obvious head gasket. Any thoughts if the head gasket doesn't cure? Cylinder aren't scored either, could it come back to life?
