catalyst-519
Thread starter- Joined
- Mar 12, 2008
- 64
Hello Gentlemen:
Following the advice of 'bktheking' I've pulled the powerhead from my '76 9.9 Evinrude as I'm doing a rebuild. It's all broken down and I've pulled the crank case apart because the gel seal between the two halves was gone and it was pulling air.
I have 2 questions:
1: When replacing the gel seal between the 2 halves of the crank case I've read in other posts about Loctite 518 or Permatex Anerobic. The question is, how much to use. There was barely a smear of original gasket between those two haves (probably why is ended up going in the first place).
2: Many of the gaskets are original and put on with adhesive. They're not commin' off without a fight. Any suggestions about a good product to soak those parts in so that the gaskets will just come off with ease and very litte sanding or scraping?
Any feedback would be most appreciated.\
Cheers--Catalyst519
I have 2 questions:
Cheers--Catalyst519
