76 85hp Evinrude engine
moboy
the engine starts but doesn't run for a half a second. I was told it was the wire box also called power pack. Any ideas about this?
emdsapmgr
Could also be the key switch. It makes ignition contact when in the start position, but loses it when moved to the "run" position. Once these old switches get water in them, they act up. I'd test the key switch first. It's a lot cheaper than a new power pack....
moboy
Thanks emdsapmgr. I have worked on cars all my life but this old girl never broke down since she was new. I did test current up to inline fuse. Had 12 volts with key in on position. What else should I test and how. Thank you, Moboy Aso as you can see I am new to this animal, the computer. Bear with me, Thanks again.
