'76 40hp Evinrude(40655A)
ZachofAllTrades
1007120902.jpgThis engine is new to me and was told by the PO that it was "gone over" to the tune of $500. However, it will not start for me. Also I'm out of time to work on it in my yard, where I have it in a barrel, because ordinances in my development require me to store in their trailer/boat parking lot. That being said, I highly suspect the coils are bad, unfortunately I haven't had time to pick up a spark tester. I badly wanted to get her runnin before I put her to bed, but alas, it doesn't seem like it's gonna happen. I took pics of the coils, and their visible cracks, also, the little yellow wire on the bottom in the top pic has been nibbled slightly, and I have no idea of it's or adjoining wires' function, will look up schematics to find out:
Any thoughts?
jasper60103
Re: '76 40hp Evinrude(40655A)
Congrats on the new motor. If you have a place to work on the motor indoors over winter, you can still prep it for next season. That is, if you can remove the motor. But I would first verify the compression is good before investing any more money in it. Then go through the ignition, fuel system and kit the water pump. Good luck.
ZachofAllTrades
Thanks Jasper. I intend to contact the marina where it was last repaired/maintained. Also, I plan to take the engine off and store it in my shed. I oughta be able to compression test with a pullstart rope to turn it over eh?
jasper60103
Yep.
Also, you can borrow a compression tester for free from auto part stores like Autozone or Oreillys.
Yea, I would be curious to know what he spent the $500 on?
ZachofAllTrades
Anxiously awaiting word from Melvin Village Marina indeed.I'll be able to borrow a spark and compression tester from a friend. Gonna need to own both at some point. Autozones and O'Reilly's and such are a good distance from here(Lake Winnipesaukee), but thanks for gettin the O'Reilly's jingle stuck in my head!
