'76 1150 lower unit won't separate
Mark47458
after removing nuts and bolts unit will not drop down, it appears the long single stud is seized. Sprayed lubricant and achieved 1/4 inch gap closest to prop but the end with single long stud isn't budging.. Even tried removing stud but failed. Any ideas That may help??
OK, That gearcase will have 5 nuts and a bolt hidden under the zinc anode. Did you get them all?
jimmbo
2 of the nuts, one on each side above the anti-ventilation plate, can be loosened but can't be removed until the unit has been lowered
James R
That long front stud will probably need heat to help break it free. Then while it's hot put the nut back on a few threads and tap it down with a hammer or apply pressure. Be careful not to crack the nose of the casing. When you reassemble use thread sealant on the threads and shanks.
