76 115 hp will not start
Plainsman
Re: 76 115 hp will not start
Yesterday I had 9.5 volts to the coil from the switchbox, today, no voltage to the coil.
timmathis
The test you need is the switchbox test. It does not go in to detail here. But it is in the wiring diagram. You disconnect the trigger wires and then you put a jumper wire from the Brown to the white terminal on the box. Then you arc the black wire to ground it should spark every time. If the switchbox is good. That will mean the trigger is bad. You need to double check and make sure what wires to jump per to your switchbox #. I cant hardly read it on my monitor. It is blurry. <br />Go here and see if you can see what wires to jump. I think you have 332-2986 Fig B.<br /> http://www.outboardparts.com/mercury/troubleshooting/printguide.htm
Plainsman
Thanks Tim. It sparked 1 time out of 5 cranks. I am getting a switchbox tomorrow.<br /><br />And Thanks to all who have helped!!!
Clams Canino
HOLD ON... try this test....<br /><br />MERCURY BATTERY-POWERED CDI SWITCHBOX TEST<br />FOR DISTRIBUTOR MODELS<br /><br /><br />This test is for the 332-2986 switchbox used from 1967-1978 on all the<br />inlines.<br /><br />This test assumes your coil is good (most all are).<br /><br />DISCONNECT BATTERY<br /><br />1. Turn off ignion<br />2. Disconnect all 3 wires on the distributor side of the switchbox.<br />3. Remove the HV lead from the coil to the center cap (remember it unscrews<br />from cap)<br />4. Reconnect that HV center lead to the COIL side only.<br />5. Position that HV lead about about 3/8" from ground (block, shrouds etc)<br />and find a way to hold it there.<br />6. Jumper the brown and white terminals on the dist. side of the switchbox<br />together.<br /><br />RECONNECT BATTERRY<br /><br />7. Check that you have +12 V at red terminal.<br />8. Turn on ignition and verify +12V at white terminal (on red terminal side)<br />9. Touch the black terminal to ground - unit should cause spark each time<br />you touch ground.<br /><br />If that passes and it won't fire at all, suspect the trigger.
Plainsman
Thanks Clams. I'm confused about step 3. I disconnect the HV lead at the coil or dist.?<br /><br />And step 4, I connect the HV to the coil side of what? The switchbox?
Clams Canino
Disonnect HV lead at coil then unscrew from dist. Then reconnect it to the coil and position it (dist end) so's that it can spark to ground.<br /><br />-W
Plainsman
How do I get the wire out of the coil, does it pull out, screw out?
Plainsman
Well it was the switchbox. Found a used one and she fired right up!<br /><br />Thanks again everyone! What a great forum this is!!!<br /><br />Eric
