75-JOHNSON
Thread starter- Joined
- Jul 2, 2009
- 55
engine is a 1976 75 hp johnson, on a 15 foot trihaul boat. the carbs are clean, and prop is correct. The issue is, about 25% of the time when you go to take off it boggs out and dies. this is especially noticeable if you slowly increase the throttle. if you give it full throttle right off the bat, MOST of the time it will quickly pick up rpm and off you go, but sometimes not. It seems like if the fuel is mixed slightly rich, the condition becomes worse. if i mix the fuel 50:1 or slightly leaner, it performs better.
my question is, is this a carb issue, if so what does a person set. Also, would burning premium fuel better the situation?
What are opinions on running 100:1 amsoil premix?
thanks for your time.
