I have a 1999 75Hp Mercury/Force 3cyclinder outboard 2-stroke which is having a few stalling issues. Boat cranks up and runs fine off the dock. After fishing for awhile, I crank the motor and then when I put it into gear its lagging, has trouble taking throttle and dies out. I then have to crank and rev it up in neutral and then when I put into gear it may lag a little but then I get up on plane and all is good until I get to the end of the day. When I come off plane and idle to the dock, once I put in reverse right before stopping it dies out. Not fun as I can't stop the boat from hitting the dock harder than I want. I am not sure if this could be a fuel or carburetor issue.
I have been seeing a slight fuel stain coming down the outside of the motor but can't find a leak inside. Thought maybe this was from the cards when you tilt the motor around.
Curious if anyone else had this weird issue.
