Hi , i have a merc 75 outboard 4 cyl not sure what year because i don't think it's the original motor for this 87 boat but probably close ser # A193757. This motor hasn't been ran in 3 1/2 years. I drained all the gas and cleaned tank, put in fresh mix. Motor started right up, ok problem is motor will idle but has a miss all the way up to about 4500 then clears up, does good at 5500. Shut it off for about 15 min , Won't start unless you re- prime it with the bulb and choke it alot. I'm leaning towards a fuel problem on this but not sure.Maybe gummy carbs. timing is right , spark to all cyl. any help would be appreciated, Thanks
