boatmercsearay
Thread starter- Joined
- Jun 25, 2008
- 1
I have a 1975 Mercury 65hp 3 cylinder,twin carb outboard.It has good compression,good spark on all cylinders(new plugs as well).I've got new fuel in it.The problem is it will not fire on #2(middle) cylinder.I tried running a short time with no water in cooling system in case water was getting in combustion chamber.Also tried squirting a small amount of fuel in cylinder through spark plug hole in case it has a broken reed and not getting fuel.(the plug seems dry when pulled).I thought with good compression,good spark and fuel it should fire)
Is it possible that #2 cylinder will not fire with the above tests because of bad reed...or?
Scott
Scott
