75 Johnson 70 slowly accelerating, spark advance?
jshfchtr
Hi, I am a long time follower, first time poster. I am the (semi) proud owner of a '85 Sea nymph CC171 with a '75 Johnson 70 horse outboard. When I bought the boat it had been sitting for 4-5 years but amazingly it fired right up and ran... for about 20 minutes until the carbs plugged up with junk. I rebuilt the carbs, rebuilt the fuel pump, all new fuel lines in the motor and did a link and sync as best I could without a service manual. Now the motor starts right up, idles perfectly, runs up to 5200 rpm and stays there but the acceleration from idle to WOT is horrible. I can lay the hammer down and it slowly climbs to about 3,000 rpm then takes off like a rocket. I think the problem is in the spark advance because when I did the sync and link I did turn the spark advance stop out a few turns. There is a sticker on the motor that says 17 degrees, is this the max advance setting? How would I set this with out having someone driving the boat at WOT and me in the back with a timing light?
Any help would be appreciated! I know this forum to be full of helpful and knowledgable people, this is my first post because ever other issue ive had had already been covered.
Many thanks!
emdsapmgr
Usually the WOT timing setting does not need adjustment by the consumer. If you changed that setting, you will need to re-time the engine according to the manual. Not an easy task for most of us. Since the timing on your engine creeps up a few degrees as the engine rpm's go up, the timing cannot be set, except at 5000 rpm's-or your timing will be off and the powerhead becomes at risk. A real chore for you and me to do. If you follow the original factory service manual, you will see to complexity of this endeavor. There is a substitute method you can use from this website. Go to the first thread of this web page, look for the "top secret" files. Inside this trove of experience there is an alternative way to set the WOT timing degrees that does not require running the engine under load at 5000 rpm's. It will get your timing close enough.. Yes, you will need a timing light. Is there any possibility that you turned the timing BACK , instead of ahead. That could explain a lot.
jshfchtr
It is a possibility that its adjusted either way. I do not have a service manual, I have been putting off ordering one because its such a common motor I can find near everything I need on forums such as this one and this is the last step to a perfectly running motor. I can see how complex the linkage and timing advance is, It took me a whole afternoon just to set the base timing and throttle blades, this is just the final step. I did try having my wife floor the motor while I held a timing light on the motor yesterday but the spash back from the motor running was getting the motor wet with the cover off and i figured there must be a easier and safer way to set it. I also attempted to pull the bottom 2 plug wires off and crank the motor at WOT in the driveway but the motor would start and run on 1 cylinder this way. My next idea is to run the carbs dry and try my driveway method again.
I will check out your top secret files, I have not searched there yet
Many thanks!
jshfchtr
Finally got a chance to fiddle with her a bit more. I followed the Joe Reeve's link and sync procedure to try and set the max advance but no matter how much or which way I turned the timing stop screw I couldnt get the timing to change. I unplugged all the wires and grounded #1 cylinder with a spark tester, pegged the throttle in nuetral and used a timing light to watch the marks at cranking speed. Could it be a bad ignition pick up? I am a mechanic by profession but ive never worked on an outboard till now, im finding them to be a completely different beast than im used to.
jshfchtr
A seperate question I have is what is the average fuel economy of a '75 Johnson 70 hp? I have a 6 gallon tank and it will take every drop of gas in there for us to run from our ramp to the lock and dam and back, about a 14 mile round trip. I used to make this trip 2-3 times on the same tank with a 25 hp on a 14 aluminum.
flyingscott
Rule of thumb is= 1 Gallon of gas for every 10 hp at wide open throttle. That =7 gallons per hr I have a similar motor 12 gallons is the minimum I will carry.
jshfchtr
I pegged the throttle by pulling the lever out and up, as far as I know that is nuetral gear full throttle. Is that wrong? Should I remove the linkage and manually hold it open?
Thanks for the rule of thumb, ive been carrying a jerry can of 5 gallons on top of my 6 gallons tank, last night we used the tank dry about a half mile from the ramp and had to full her up with the jerry can. Our first long trip on it and sounds like typically fuel usage.
fireman57
Try bumping the primer solenoid with the key when it is taking off and see if it picks up quicker. If I remember right there was a service bulletin that required you to rejet the carb as it had a stalling issue between the low and high speed jet. Also, if it is smooth but takes a while to get going you might have the wrong pitch prop. If you have access to a lower pitch prop you might want to try that first.
emdsapmgr
Regarding the spark advance. Does the timer base rotate smoothly under the flywheel? Sometimes the grease under the timer base dries out and gets sticky. You might find the timer base is not moving smoothly with the spark advance arm.
jshfchtr
Sorry for such a long wait between posts, works been backed up and Im finally getting time to works on my own projects. Bumping the key causes the motor to bog even more, ive read the articles about putting grease on the throttle shafts and drilling the jets but every thread i read said Bumping the key causes the motor to run better (opposite of what mines doing).
I did not check the time base yet, but it is my next piece to check. Besides being able to freely move, is there any more things to check in a time base? I try to avoid ebay parts and would hate to spend $250 on a parts I cant prove to be bad.
jshfchtr
As for the prop, you could be right about that. Knowing the guy I bought the boat from I wouldnt be surprised to find the wrong prop on it, I never checked. I dont trust my tach too much, but it does show ~5200 at WOT, a quick search showed that to be a bit low. Ill get the pitch numbers off it tonight and cross check to make sure.
