lakeozarksman
Thread starter- Joined
- Jul 5, 2004
- 3
I have an intermittent problem with my 1996 75 HP Mercury/Force. Typically, it starts and runs fine. Occasionally, however, there is an intermittent problem where I cant get the engine to start. In these cases, when I turn the key to start, nothing happens. If I use the trim control to raise and lower the motor a few times, then the motor starts up when I turn the key. Im assuming that raising and lowering the engine jiggles some loose connection and enables the battery current to reach the motor. <br /><br />In some situations, everything goes dead, the motor wont start and even the trim controls wont work. In this situation, Ill jiggle the battery cables that go from the battery to the motor, and eventually the motor will start. Sometimes I have to jiggle the cables many, many times before the motor will start. I cant really tell if jiggling the cables actually helps, but the motor does eventually start. <br /><br />The cables have no signs of cuts, breaks or cracking. And Ive used a multimeter to check the cables while moving them, yet they always check out fine with minimal resistance. <br /><br />Do you think I have a battery cable problem or is it a component problem in the engine where the cables attach? I dont think its an issue with the starter, but I may be wrong and I am open to suggestions. Replacing the starter and cables would be an easy job, but I want to see if anyone thinks there might be another problem for me to consider before I start replacing parts. <br /><br />Could it be a problem with the key switch/throttle/trim controller?<br /><br />Any other ideas?<br /><br />Thanks for your help!
