75 Evinrude 70hp Prop install Newbie Question
skinners1
Recently installed new prop on 75 Evinrude 70 hp motor. Fired her up on muffs last night to check out carbs etc... after rebuild. Ran for just a few minutes in neutral only, never put her in gear. Noticed after shutdown that grease / greyish color and fairly thin, not runny but maybe the consistency of a chocolate milkshake was running out of the prop and onto the ground. Newbie here, what have I done wrong? I did install a new thrush bushing with prop, but thinking I may have installed it backwards, should the gasket portion be facing the prop or the motor?
