75 Chrysler 75hp outboard firing issue
awillige4
Hello all again so update..... Outboard quit running wouldn't restart.... flywheel pin not sheared so thats good. New cdi, new coil, new ignition switch, new plugs and wires. I am only getting fire when I turn the key from the run position to off I get one spark. No fire when cranking. No kill switch installed I am at a complete loss. Any ideas?
Frank Acampora
Is the blue wire attached to the "I" or "A" terminal of the new ignition switch? Is the new switch a 6 terminal - push-to-choke switch? At the engine is the red CDI wire attached to the red terminal? Is the blue wire attached to the CDI blue wire and if an electronic distributor is the blue to the electric eye also ATTACHED THERE?
MickLovin
Master Chief Petty Officer
Send us some pictures of your electrical set up on your cdi coil and dizzy, and if you can your ignition switch.
