Re: 75 9.9 running on only bottom cylinder
How are you testing spark?
Making a spark plug spark in the open air is not a good measure of how well an ignition performs. Remember that spark plug has to fire in a pressurized combustion chamber with fuel.
If you don't have one, get a hold of a spark gap checker, sold in most auto parts stores.
Looks like this;
Ignition should be able to fire across at least a 7/16ths gap.
Have you pulled the flywheel at all to inspect the ignition? Your points may be dirty, misadjusted, or burnt out.
