'75 50hp kills when put in gear
PDP1979
At times the engine will die when it is put in gear. It will idle n rev up with cold start but soon as it goes in gear it falls off. The motor has sat up for a year so i flushed the carburetor. When at open throttle i do have an air leak as the ball goes flat and the motor sputters some.also after it dies i have to choke it again to start.
oldboat1
Think the primer bulb going flat might indicate a blockage between the bulb and the tank. Is the tank vent open? If it turns out there is an issue with a carb, it usually needs to be taken apart and cleaned. Varnished fuel after sitting is usually the culprit.
Snebber
Had thesame problem on my 81 90hp. Couple cans of seafoam mixed with the fuel cleared it up. Can be worth a try before rebuilding the carbs. Also an air leak in the fuel system can cause it to run lean, can do more damage down the line if not fixed.
flyingscott
If the ball goes flat you do not have an air leak. Take a closer at the tank vent or look at the primer ball itself and make sure the arrow is pointing towards the motor.
