pcrussell50
Thread starter- Joined
- Sep 21, 2008
- 296
bought this boat last fall, and it runs like a top.
still, i decided to drop the lower unit and change the oil and the water pump as a preventative measure...turned out to be a waste, because the impeller and oil were in great shape. oh well, now i have peace of mind.
that was all fine, except that i noticed the splines at the top of the driveshaft are worn. they are no longer dull and flat on their tops, they are now sharp. it doesn't appear to be from any singular incident, just plain old age, as far as i can tell. there's no galling or anything.
now the part i need opinions about. i can get a new shaft for like $550...and I might just pony up for that...but...i don't want to do that if there is a high likelihood that the crankshaft's internal splines are equally worn.
i'm clinging to hope that the crankshaft spline material is harder than the old '75-era stainless driveshaft's splines, and is thus probably not worn too badly.
what do you guys think? likely that the crankshaft's splines are ok? if there is high likelihood that the crank's splines are good, i might just pony up for a new shaft.
it would break my heart and make me sick to throw away this otherwise great running motor...damn.
-peter
-peter
