Weak fuel pump? You can do a test. Take a buddy with you to the lake. Have him constantly prime the fuel hose bulb when running at WOT. If the engine keeps running well at WOT, likely you have a fuel delivery problem-including the possibility of a weak fuel pump. The engine may be consuming more fuel than the pump can deliver-eventually draining the fuel bowls and causes the engine to slow till the bowls can refill.
