Hi everybody.. noob here.
Just bought a 74 Ozark tri hull.. I new it had issues, but wow!
It started when I noticed a bolt head in the bottom of the ski locker and decided to pull it out.. the song lyric came to mind "and up through the ground came a bubblin crude".. had to cut the bottom out of the ski locker to get all the water/muck out. Then decided to see why the floor felt soft.. Long story short, the entire stringer/bulkhead system is one large
drainage system and each "compartment" between bulkheads drains into the main stringers on either side of the ski locker.
Once I got all the completely rotten plywood, dirt, muck, mouse nests, etc cleaned out of each section I was able to get an idea of how it all worked. The only thing I can't figure out is the drainage for the forward storage compartments in the bow, I even poured some water in but was unable to track it.
All of the plywood deck was wet from the cockpit aft and all that was left was the fiberglass skin.
Here are a few picks so you can get a better idea what I'm up against.
I've never done fiberglass work before. I'm not sure exactly how tackle the new deck.. I've read plenty of threads on the subject and feel I can do it, just not the best way to do it. Here is what I'm thinking.. the sidewalls come all the way to the existing glass deck (I left a few inches when I cut out the compartments) and I have the rotten plywood removed. Is it best to try to slide the new deck under the existing skin on the edges? or build some shaped blocks to fit under there and just run the edge of the new deck right up to the interior side walls? If I go under, I have no way to attach the deck to the hull, if I go above, I can attach to the interior side wall... or do I let it float at the edge and not attach to the interior side walls but just caulk the joint? I don't know how the interior side walls come apart, they are not part of the cap, so even if pulling the cap was an option (it's not) it would not solve the problem.
I just have so many ideas/options swirling around in my head it is hard to get them written down coherently..
Any input would be appreciated.. hope I made sense with all this.
37 years old and even with all that muck and water and poor draining etc, she still stayed afloat. I think she's earned a new lease on life..
