74 Johnson 50 "50es74m" dies shifting into gear
Lostboatman
So history first: Recent purchased my first boat, it came with a Johnson 50es74m. Initially it wasn't getting fuel to the bottom cylinder it ended up being debris in the slow speed needle of the bottom carburetor but I also bought a carb rebuild kit for the float and needle the mechanic that worked on It also lowered the idle rpm. The motor ran awesome for about 2 hours
Now...
it started sputtering /I smelled fuel strong with the motor cover on..so I headed back to shore and it died as I got to the dock.
the next day, back on the water whenever I shift into forward or reverse the motor would stall. It will stay running (very well) if I manually control the throttle on the motor. So I headed back to shore yet again. Testing it out of water it still runs fine and I can shift forward and reverse engine doesn't stall or slow down. Now I know In and out of water are different beasts for these motors but I'm not sure what I should be looking for. Any ideas? TIA
Joe Reeves
Remove s/plugs.... check compression... what are the psi readings?
Use a spark tester whereas you can set an adjustable gap of 7/16". the spark should jump that gap with a strong blue lightning like flame... a real SNAP! Does it? The gap is important.
If the two areas above are as they should be, I'd suspect that debris is breaking loose within the fuel lines and causing a clogging effect within the carburetors, probably with the float needle valve and/or the high speed jet.
Lostboatman
Okay so I could maybe look at cleaning the carbs again? I'll have to buy a compression tester too I guess. Can't hurt to have one. I can check the spark later on. Just find it odd that those would be part of the issue when it has all of its power when I run the throttle manually.
Joe Reeves
Apparently I missed that.... Are you saying that your remote controls DO NOT open the throttle butterflies now? If so, that problem should be obvious. You say that you're running the throttle manually... BUT... you do not say actually in detail what is happening as a result of whatever you're doing. I can only assume that you have the hood off and are moving the throttle butterflies to the horizontal wide open position with your fingers.
Lostboatman
Yes with the hood off in the water if I run the throttle butterflies manually (it's two separate carbs, linked together through the rods for choke and throttle, the top carb has the fuel intake and and feeds the bottom carburetor with another fuel line) I can keep the motor going and once it gets past the initial low rpm and wanting to die it kicks in and runs fine unless I let off the throttle and then it wants to die again I don't open it wide open and I'm almost positive the remote control does still manipulate the throttle. Sorry, I'm not the best with outboards so I may not provide the most useful information right away lol
F_R
Honorary Supreme Mariner
Make sure the spark advance/timer base is not sticky. It is moved by a spring in the pivot of the vertical throttle arm. If it doesn't move freely, the spring simply winds up without moving the timer base, however the carbs will open. All this results in the carbs opening without synchronized spark advance, and the motor will stumble and most likely stall.
EDIT: Likewise, if you are manually opening the carbs by fingering the linkage rods, you are not advancing the spark and it will stumble and most likely stall.
Joe Reeves
As F_R states.... check the timer base for sticking. Also, check to see that the throttle butterflies open fully when full throttle is given via the remote control. If these two area function as they should.... you're overlooking something within the carburetors. Clean them again and pertaining to the high speed jets that are located horizontally in the bottom center of the float chambers, way in back of the drain screw... carefully clean them with a piece of single strand steel wire!
Lostboatman
So I tried the things suggested. Still no compression tester but spark seems okay. Tore the carbs off again and cleaned them. Adjusted a spring back to where it was before a mechanic friend moved it. Headed back to the lake now to see if cleaning the carbs helped. I recorded a video to show how it shifts from the remote control. It does still control the butterflies from the control as well and they do open all the way
Lostboatman
Another update. I'm on the water and besides having a little challenge with the idle when I start the motor and it not wanting to stay running without higher rpms , it's running fine again and has all of its power. As an aside she clunks pretty good shifting quickly into gear. But I'll continue fishing and enjoy my day. Regardless
oldboat1
stalling going into gear says to me the idle mix may need attention -- could be some blockage in the idle passages up at the top of the carbs, or an adjustment needed in the needles. For cleaning, the core plugs need to come out before soaking (and maybe some gentle poking). For adjustment, try setting the needles about a turn or a turn and a half out from seated, and work from there -- adjust leaner by 1/8 turns until the motor backfires a little or stalls, then open about a quarter turn. rpms will increase with adjustment, so just throttle down. As part of the test for setting, the motor has to shift into gear smoothly (no jarring), without any hesitation or stalling. (Read through Joe Reeves' instructions in the sticky up at the top of the forum.)
You have to do the adjustment with some back pressure, so muffs won't quite get it -- may idle and shift fine after adjusting on muffs, but stall in the water.
Lostboatman
I'll give that a try next time I go out, can't hurt to adjust the needles a bit. I had read that 1 1/2 turns back from soft seating was just about right. But since it still has some trouble idling and not dying out maybe I can get that taken care of with your advice.
oldboat1
Yeah, initial settings are intended to get the motor up and running (finer adjustments after warm up). Good luck with it.
F_R
That timer base is not at all moving as it should in your video. It is not coming anywhere near the idle stop adjustment screw. You ought to address that problem before tackling other issues. Idle speed is affected by the carb butterflies and needles adjustment. But the MAIN thing controlling idle speed is the spark retard. It all has to work together--"synchronized".
Joe Reeves
(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note 1: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
Note 2: If the engine should be a three (3) cylinder engine with three (3) carburetors, start the adjustment sequence with the center carburetor.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Lostboatman
Messing with the remote control last night and the timer base seems to shift really stiff into forward so I'll take your advice and look into that problem. Thanks for watching the video F_R and thanks for the advice. Also thanks for the additional tuning details Joe reeves I'll get to that asap also
Lostboatman
So the linkage absolutely wasn't working right. The connection inside the remote control was not even close to being in the right spot.
I opened the remote control to change out the ignition switch (with some help from another great post on this forum) and found the problem was that there is a slot inside where the shaft goes to stop movement and it wasn't In there. Fixed that and now it starts everytime and idles without dying and doesn't clunk into gear.. Still have to adjust the carb needle positions though, thanks to you all I've got another issue solved.
Thanks to all that commented.
