'74 Johnson 25R74M Short to long shaft conversion
zstir
I own a Johnson 25 HP shortshaft model 25R74M ser. no. E4020267 that runs nice. I want to convert to a long shaft. I found a 25 HP longshaft Evinrude Model 25253 R ser. no. E0002553 for $100.00 are these the same year, and will the parts work? Is it a worthwhile project or should i buy a 198? chrysler 25 HP electric start that a neighbor has for $500.00 ?<br />Thanks for your help,<br />Mark
Paul Moir
Re: '74 Johnson 25R74M Short to long shaft conversion
Welcome to Iboats, zstir!<br />Evinrude 25253 is a '72 25hp. It's lower unit should bolt right onto your '74.<br />I would go with the Johnson. Parts are easier to find and cheaper, and IMO it's a better engine. If you want electric start, look for a parts engine that's got it already and swap it over too.
zstir
Thank you Paul for the welcome, I appreciate your input.<br />Mark
