74' Evinrude 50hp No spark, new stator, rectifier and coil.. please help!
mensing7c
Hello all! I rarely post but I have run into a year long no spark problem that started after being put away for the winter RUNNING!
Motor turns over well, but just turns over no spatk
Following my manual I tested my power pack using test light to each coil location in pack. No power going to coils, so I bought a stator and rectifier. ( Original statir was dripping goop) still no spark!
So I was leaning toward power pack, until I just tested the timer base wires in power pack and got no reading on low ohms setting on multi meter.. if this reading is correct, I'm not sure what to do now.😑
Any help would be greatly appreciated!! I am beyond frustrated with this now. Thank you!!
boobie
Go to cdielectronics.com for ignition trouble shooting.
mensing7c
Unfortunately I have been to the website, that's why I am at the stage I am now. Everything I have tested seems to be bad. Timer base shows no reading on ohms scale, and power pack tested with test light shows no power at both coils...
