Question for you guys. I just purchased a 1973 Johnson 40hp, had the lower end gaskets replaced (leaking) and a new impellor replaced as well. I put the engine in a BIG bucket of water, and ran it at idle. My questions are, how can you tell if the water is circulating inside? I heard that my model didn't have a stream of water that came out of it. Mine did not have an water coming out of the rear, when it sat at idle, so I want to make sure when I go out on the water, that it won't overheat. So can anybody tell me how to check if it is properly circulating, i.e touching the heads, water spraying....thanxs!!!
