73 Johnson 135 carb adjustment?
rodknee1231
Just rebuilt my powerhead and was wondering how I and what.type of adjustments I need to do. Specifically where the adjustment screws are I did read the top secret file on the procedure but I'm still a tad hazy on where the screws are and what all adjustments these carbs have. Obviously they are a fixed jets but if I get it running well do I still need to worry about dangerous lean or rich conditions ? Is there's an air screw? O and the needles looked like new as well as the seats. Thanks in advance
emdsapmgr
This older carb has just an idle and high speed fixed jet. The 3rd jet (mid jet) came out in later carbs. So, not really much to adjust from a carb standpoint. It would make a lot of sense to set/reset the sync and link. When you do this, the relationship between the carb opening and the spark advance is re-established. Probably a good idea to re-do this, as too much spark advance and too little throttle opening could result in a lean condition. The sync and link is detailed correctly in the factory service manual for this year. Tearing down the carbs for cleaning and removal of all the jets for visual inspection for debris is a good idea.
F_R
Honorary Supreme Mariner
There are NO adjustable jets on those carburetors. Both high and low speed are fixed jets. Wrong jets or dirt in them will make it lean.
rodknee1231
Ok that's what I thought. I have took them apart and put them in a ultrasonic cleaner so they are clean. I'm in the process of trying to figure out the whole timing and sync procedure on these. Kind of o different animal being my first time messing with a outboard
emdsapmgr
Your 135 is a relatively simple engine. Easy to work on. All-electronic ignition, simple fuel pumps and carbs. Armed with a factory service manual, you'll find them easy to work on. I ran a 76 135 for a number of years. Your 73 has some of the highest compression heads every produced for the V4 crossflow engines. Check out this website: outboardbooks.com for an original factory service manual. Good luck!
Silvertip
Unless you used a dental tool or similar probe to clear each and every passage in the carbs, you still do not have clean carbs. A spec of dirt, debris, or varnish in any jet can cause a lean condition and you ruin a rebuilt powerhead. Lean running is a major cause of engine failure.
