73' Evinrude 65hp Triumph...no key...
Pandorrah
hey all!!!...
the Hub and I just bought a '73 Crestliner project boat...our first...but no key for the ignition/throttle...what to do????...any advice on where to start would be wonderful...
thanks in advance!!!:)
Al-53
Re: 73' Evinrude 65hp Triumph...no key...
you can buy a replacement ignition switch.....is the switch in the controller..or is it dash mounted.....
Al
Pandorrah
it's in the controller...thanks for responding so fast!:D
Daviet
Look on the face of the switch, where the key goes in, and see if there is a number stamped on it, take the number and check with your local marine dealer and see if they can order you a key.
Pandorrah
thanks!!!...just looked, no number...
bktheking
Any good OMC dealer will have a rack of keys, do what I did, remove the ignition switch and take it in, I think we went through 8 keys before we found one that worked.
