TaperSteve
Thread starter- Joined
- Jan 6, 2013
- 9
I've got a 1973 Evinrude 25hp 2 stroke thats been sitting un-used for about 3 years. I want to see if I can get it going again so what should I do to start this motor thats been sitting for that long?
I was told to take out the spark plugs and squirt some oil in the cylinders. Should I do this and if so what kinda of oil (2 stroke oil, motor oil, 2 stroke/gas mix)?
Then I read in the manual to slowly pull the crank 10 times to get the oil circulating again and then try to start it. Does thats sound right?
I lost the key for the electric start but it has the back-up pull start. Does the key have to be in the on position for the pull start to work?
Thank you for all your help in advance!
Steve
Steve
