73 Evinrude 18 hp water issue
St111
Wanted to see if anyone else may have had this issue and has a solution. 73 Evinrude 18 hp,replaced impeller along with almost everything else. When running,there is a stream of water coming from a small round hole on the pan. The water shoots up harder with more throttle,filling the pan with water. The hole is next to the shaft that attaches to the tiller handle. Any ideas are appreciated. Thanks in advance
54bobby
is it a hole or is it leaking from between 2 surfaces and a gasket? the exhaust cover plate is in that area and if the gasket blew the water will go somewhere. check your plugs for signs of water intrusion.
F_R
Honorary Supreme Mariner
Agreed, the pan is merely collecting the water coming from a leak somewhere above that (stuff runs downhill). In addition to the gaskets mentioned, another common leak is the core "freeze" plug on the bottom of the cylinder head. It is thin and rots out. Can't see it without removing the head.
St111
It's not coming from a seam or the power head,it's definitely coming up from a small round unthreaded hole in the bottom of the cowl pan. At idle it just spits a little but with throttle it shoots up and hits the power head and corner of exhaust cover. Thanks for the replies
54bobby
what is this hole in the cowl pan located over top of? there are drain holes in the pan for water and or fuel . if the engine is not trimmed correctly it's possible that you are just getting a splash back from prop wash and the faster you go, the more powerful the spray. are your plugs clean? is the engine discharging water from the pee hole? are you over heating/
St111
No overheating,good discharge from pee hole. The hole is just to the left of the exhaust cover. The hole goes down into I guess you would call it the exhaust housing or leg under the pan.
I am not there to have a look see.-----Salt water motor ?-----Could be corrosion or gasket under the power head is leaking.
F_R
Certainly is an interesting case. The powerhead completely covers the top of the exhaust housing. So how can a hole in the pan extend down into the exhaust housing? Any way you can post a picture?
Don't leave us hanging on this one. If you discover the cause, let us know so we will learn something new.
F_R
I don't have a motor that I can run out and look at for comparison. Hopefully, somebody else here does.
JJBoatr
My 73’ 25 hp has a screw in that hole, same power head as your 18
St111
Well I took the power head off,not lucky enough for mine to be a bolt hole,it's just a hole. Gasket looked good but the exhaust seal was shot,which is an obsolete part so I'm going to cut some rubber pipe insulation and fit it in. Thanks for the response.
Chinewalker
Should be a stud in the exhaust housing that comes up through that hole, with a nut on the end. Hard one to reach - I have a garage sale cheapie wrench that I heated up with a torch to bend the box end a bit to reach in there.
Is there a stud in the exhaust housing where that hole is ?----Post a picture of the fasteners you removed to remove the POWERHEAD.
