73 evinrude 135 wont start/starts hard
harbor roach
I have a 1973 evinrude 135 hp.Started and ran?Now turns over hard and kills the battery?1 cylinder is really getting gas.Reed valves look ok?<br />Possible a bad cylinder???Going to rebuild the carbs any other ideas?<br />Thanks,<br /> Harbor roach
Solittle
Re: 73 evinrude 135 wont start/starts hard
Start with a compression check. Let us know the results. Also when you pull the plugs tell us what they look like by cylinder so we can get a sense of what is going on in each cylinder.<br /><br />Donig the carbs is a good idea. You will also need to do the water pump and change the gear oil unless you know when these things were last done.
harbor roach
#4 cylinder was low?am thinking of pulling the head tomorrow.I changed the lower unit lube at the start of the season.The guy i got the motor from said the water pump was replaced???Not always the case??<br />Thanks,<br /> Harbor roach
harbor roach
How would lower unit grease and water pump affect starting??<br />Thanks,<br /> Harbor roach
