Ok so I have a 73 Evinrude 135 that's been sitting for the last 2 years. I placed a set of water muffs on the lower unit and it started right up. There is no tell tail on this motor but I do have two small holes right under the motor. If I recall correctly, water will spit from these two holes a low idle. My issue is that I only see water spitting from one side. Are these two holes connected together or is one hole for each side of the motor?
