73' 9.5 Johnson- No Power at WOT
Jgeisler
Just did a tune up, and have good spark on both cylinders. However, no power at WOT, just a slow steady crawl.
Thought are a bad fuel pump...old fuel line and tank...(what should the ball feel like?)...or gummed up carburetor?
Any advice is much appreciated!
Honorary Supreme Mariner
Does spark jump a gap of 5/16" , yes or no.-------Compression checked ?
F_R
Your motor is running on one cylinder. Carburetor won't cause that. Have you tried the simplest thing---new spark plugs? Can't hurt and that might be the only problem.
Fuel pump is working if it continues to run. HOWEVER, it is possible that the diaphragm is ruptured, flooding one cylinder. Remove screws holding it to the motor, (hoses still connected), then squeeze prime bulb while watching the hole in the backside of the pump. Does gas squirt out? It should not. If it does, diaphragm is holed.
