73 20 hp merc lower seals
jdhucks
Hey everybody... Can somebody please help me find a seal kit!?!? Ive looked on the web with no luck. I called a few local shops just so they can laugh at me...
73 20 hp mercury
Faztbullet
Re: 73 20 hp merc lower seals
No one carrys a seal kit for this model not even OEM.:( You will need to purchase seperately and below are the seal and O-ring numbers. Examine the driveshaft wear seals run in water pump base, if grooved or pitted install a speedi sleeve to repair.
prop seal.....................18-2019
prop seal.....................18-0595
carrier o-ring................18-7163
water pump base seal....18-2004
waterpump base seal.....18-2006
shift shaft seal.............18-8308
water pump base o-ring..18-7164
shift shaft o-ring...........18-7180
jdhucks
thank u so much!!
