- Jul 7, 2010
- 15,125
Howdy all:
I'm starting a new thread because the problem is a little different than the header on my OTHER one suggests:
The 165 Stringer is a Chevy inline 6 (250), and I'm getting zero compression on cylinders #2 & #3. Under load on the water the boat has no power, runs way rough and makes a pretty consistent popping noise while running. I'm guessing at a bad head gasket ... does that make sense, or should I be checking something else?
If it is a head gasket: is that something that a novice, and not that good, mechanic can tackle?
