I would do a cursory cleaning and then remove the plugs and do a compression test first. And that is for a few reasons. First to make sure it is not locked up...you really never know. Secondly to see if there is good enough compression to support combustion and not waste time and/or money if it is beyond running. Thirdly, if it passed the usual compression capabilities then maybe squirt a little 50:1 fuel/oil mixture in to get things loosen up to run. And finally you can also see if the lower section is working in forward, reverse and of course neutral. The if all that seems good, check the lower foot for oil. If it looks clean, let it stay for now. If it looks milky or water comes out, that has to be taken care of before running to keep from causing more damage. Then of all that looked okay, you can try cranking it and if it fires, great. But if it doesn't then you need to test for spark and work that issue. But either way you go, I would remove the carb(s) and install a carb kit AND a water impellor, minimum regardless how well it seems to run. Also look for any worn, cracked and/or broken wires and clean all connectors until they are shiny clean metal.Replace all fuel lines and maybe even the fuel pump diaphragm too. Those are parts that can and will go dry and crack... Basically just use common sense and it will all work out... JMHO!
