Re: 72 Johnson Evinrude 65hp won't start
In the duplicate thread that you have on this issue, you mention that you believe that you are getting fuel delivery. but no spark. You also mention "replacing the amplifier," and getting a "coil kit."
If your motor is a 1972 65hp, it doesn't have an amplifier. The first thing that you should do is to post the exact model number of your motor, so that we can be sure of what components you have and better advise you. The data plate with the information should be on the port side transom bracket.
If the motor is, indeed, a 1972 65hp, my first suggestion is to check the key switch in the control unit. Once you have confirmedwhat motor you have, we can advise you on how to do this.
