72' Johnson 9.5 seahorse propeller "slippin" mid range RPMs
Jonesy89
The only way I know how to explain what is happening is that after the motor warms up the propeller seems to slip once I get to mid rpm range. It will do it repeatedly and evnuntually get worse and do it with the slightest increase in throttle. I've been told it's "blowing the prop out" due to trim and weight distribution but I spent 9 hours today playing with trim and weight with my buddy and our fishing gear. The hull is a 14ft aluminum flat bottom Jon boat. I've crossed out trim and weight. My only other ideas are some kind of freak air bubble forms right at the prop somehow every time I hit the lake or that there is some kind of mechanical issue. So I pull the prop, pin is intact and the prop cannot be spun by hand while in gear without applying a sturdy amount of pressure, what counsider to normal. Everything I can think of checks out normal but the motor continues to slip or spin after a run across the lake. I have some video footage from today as well if that would help. Any and all help is appreciated, and if you just read all of that, God bless you lol
hardwater fisherman
Maybe the prop is spun on its hub. Mark a line from the hub to the prop and run it until you have the slippage. Then if the lines dont line up it is the prop.
iggyw1
Ensign
This is exactly what needs to be done to check to see if the prop is spinning on the hub. I had a 75 H.P that would slip at 1/2 throttle or greater, but below 1/2 throttle it was fine. I tested it in gear spinning the prop by hand and it seemed fine too, but it was not. I scribed a few lines on the hub and on the prop ) take the prop off to do this) and the lines were way off when I tried it again on the lake. Replaced the prop with a used one I bought and it was 100% fine!
Jonesy89
Made my marks and it is indeed slipping. I'll let yall know how the new prop works out. Thanks
