72 Johnson 85hp half fire
Honorary Supreme Mariner
You just never know with these older amplifier systems.-----Maybe it is a conversion to a points / condensers / 12 volt coil.----Without peektures it is hard to tell.
F_R
That was my gut thought also. Except post #14 says he checked the amp. Sounds like we are being had.
Joe Reeves
I don't understand... he said that he has a 1972 85hp Johnson... a points ignition system with Battery Capacitance Ignition with no spark on the port bank. That, to me, spells out either one bad set of points or a grounded point lead wire. What am I missing here?
If it was the coil, amplifier, distributor cap or rotor that was flawed... it would affect more than just cylinders 2&4.
Tubbsharper
Exactly what joe said but I have had distributor caps fail. And F_R if anyones being had it's ME:facepalm: will try to get out an snap a few pics for those who are in disbelief
And where are the condensers ??----And what is the part # on the distributor cap ?-----What are the cylinder numbers on the cap and what order are they in ?----Did this motor ever run properly for you ?
Joe Reeves
Yeah, that sort of stopped me for a second, then I remembered that the 100hp with Battery Capacitance Discharge ignition had points which were simply acting as a switch to the amplifier's circuitry, replacing the sensor & magnet setup used on other models... and no condenser was required. Getting to an age where it's difficult to remember it all (I saved the manuals).
Tubbsharper
Yes for about 20 minutes the sputtered and poof still running just TWO cylinders not backfiring or dieing out. I will put pictures on later for those people who would like to see
When did the motor perform properly for you out on the lake and how long have you owned it ?-----When you answer we may be able to steer you in the right direction.
Tubbsharper
Never had it on water only had this one for about 3 months now. when I got it was missing starter so kinda was a shot in the dark de-carbed her new fuel line plugs an she fired right up
Tubbsharper
Okay got the timer base out... SORRY to you all . You all was right no condensceners just pick up points so???
There were a number of questions that still have not been answered.
Joe Reeves
Dropping out of here... been neglecting the yard work... cat jumped off the patio step into the grass and disappeared... buildings need pressure-washing... house needs painting... never ending!
Nothing more I can add to this thread... re-read everything Tubbs and cross your fingers. Good luck.
Tubbsharper
thanks to all who gave effort and time found the problem. The timer base wire was cracked all 4 get fire now to set the timing
