Okay got out and checked the gap its what the manual states it to be set and its all lighty lubed and clean just stopped firing on 2&4 the other day. ( E.G. Half burnt distributor? )
In checking spark directly from the coil... set the air gap to 7/16"...... From each spark plug lead, to 1/4". The air gap is important... nothing else will do!
If indeed you do not have any spark on cylinders 2 & 4 (port bank), double check the points as follows below.
Regardless of what the manual states.... clean those points with either lacquer thinner or acetone, then set as instructed here.
(Point Setting Of Battery Capacitance Discharge)
( Ignition Models - 1968 thru 1972)
(Some have points - Some do not)
(Joe Reeves)
The points must be set to .010 but no wider than .010..... BUT in some instances due to a possible slight inaccurately machined crankshaft lobe or a slight offset of one set of points, a setting slightly less than .010 would be required as follows.
Whether the crankshaft has two or three lobes, when setting the points, check the setting of the points on each individual lobe by rotating the crankshaft by hand.
You may find that setting one set of points to .010 on one lobe, then turning the crankshaft to the next lobe, the gap measures .011 or .012 (too wide). This is where you would need to close that gap down to the required .010. A gap too wide can result in a ignition miss when throttle is applied.
Bottom line, pertaining to the point setting of your 1972 85hp model at the various lobe locations
____ .010, .009, or .010, .010 is okay____ .010, .011 is not!
Tubbsharper: To be sure all of us are on the same page The cylinders on a V4, standing in back of the engine, facing the spark plugs are numbered as follows.
2.....1
4.....3
You are speaking of the port bank, cylinders 2 & 4 ?
